Broke down and ordered the Dynomax Coated headers today from Jegs
What are the best Gaskets and locking Header bolts to Install So I will have no Leakage Problems
Thanks for the info!!
Re: Broke down and ordered the Dynomax Coated headers today from Jegs (Alwyn678)
stage 8 locking bolts are great!!
if you never wanna have a blowout, then use the metal gaskets...(available at jegs and summit)
DONT USE THE GASKETS THAT COME WITH IT!!!!
:cheers:
:cheers:
Re: Broke down and ordered the Dynomax Coated headers today from Jegs (daily_driver)
also make sure your engine isnt running lean cuase thatll cause the jet hot coating to eventually flake off..... then itll look like crap.
St. Jude Donor '08-'09
Which gaskets did they suggest? I couldn't find any with the oval pattern that dynomax uses. I'm running the paper gaskets that came with them right now. I want to get those things replaced ASAP!
Thanks,
[Modified by e3pres, 11:33 AM 1/14/2002]
Thanks,
Re: Broke down and ordered the Dynomax Coated headers today from Jegs (e3pres)
i believe they are Percy's gaskets.....But I am sure they are copper..They say that most folks end up buying them EVENTUALLY :cheers: .......Actually they are called copperseal and Jegs sells thenm for like 35 bucks
[Modified by Alwyn678, 12:02 PM 1/14/2002]
Thanks. I want to get something good on there before I fill up my pipes with that paper crap. :)
for what you get....I was.
Re: Broke down and ordered the Dynomax Coated headers today from Jegs (ylose)
Yeah after seeing the pics from the thread U are so beautiful to me...I had to get them...They just look too good for the Money
So ya are saying that topic wasn't about his g/f- I didn't look since mine is fine. :cool:
I just received mine yesterday. They have little machine scratches in them. The scratches don't penetrate through the ceramic coating, so should I not worry about them and keep the headers or should I send them back for an immaculate pair?
