Dash Pad, what is the trick to get it out?
I am replacing the dash mounted speakers in my "72". I knew that removing old dried out dash pads is very tricky, so I thought if I could just lift it enough to access the nuts, I could drop the speaker and snake it out. Well, this was not to be. I still managed to crack the pad. :cry However, this did allow me to lift the dash high enough to remove the speaker. :) In hind sight I should have just left the old speakers in and just added speakers to the kick panels. As far as I can tell, there is no way to remove the pad without a fair amout of flexing which WILL be lethal to and old pad.
Re: Dash Pad, what is the trick to get it out? (KJL)
I just took mine out yesterday from my '72. I have all the lower dash out. I raised the left edge about an inch, then pushed the right side down as snug as possible, and with a very slight pinch in the corner it came out ... not a big deal. Maybe having the lower dash panels out was the trick.
Re: Dash Pad, what is the trick to get it out? (sray454)
they are correct.
you have to bend it in the middle a bit..
i just installed a new one from corvette america not too long ago..
4th Gear
Re: Dash Pad, what is the trick to get it out? (daily_driver)
How did the one from Corvette America compare to your original dash pad?
I need to buy one for my 69 but I'm not sure who to buy from.
Thanks,
Bill
Thanks,
Bill
Re: Dash Pad, what is the trick to get it out? (mvwjd)
well it was 200 bux !!!! it is a not quite perfect dash pad from corvette america...
i cant find anything wrong with it!!!
it is perfect!!
:lol: :lol: :lol:
saved me a 100 bux.
it is perfect!!
:lol: :lol: :lol:
saved me a 100 bux.
I did my 71 last year and agree you have to bend it in the middle. One trick I used was to warm it up with some heating pads for about an hour. Don't know that it made a difference, but mine did not crack.
