McLeod Industries Magnum force clutch and flywheel
I have a very lightly used Mcleod Magnum Force clutch and aluminum flywheel. We used it for only a few sessions. You can tell by the starter ring gear that it has only seen a starter a few times. This unit is rated for 900lb/ft, it is twin disc, it weighs only 21lbs and it is the pinned version. It costs $1300 new. $750 obo
I also have a brand new in box setup for $1000 if anyone wants that.
Is it broke in? meaning, could someone install it and play? Flywheel is included, correct? Any other supporting mods needed to make it work right? I know alot of guys with the Textralia Twin end up needing to.
It may need a different throwout bearing but I think it works with the stock one, not sure. McLeod would be able to tell you for sure. It is broken in, so you can install and commence hauling ***. Aluminum flywheel included.
http://www.mcleodind.com/downloads/p...DFs/Page_7.pdf
It looks like this. It is new in the box. I will get some pics shortly and post them here.
Ok turns out that the clutch that I thought was new is not. I took it apart to take pics and it has been used. Very little use though. You can still see the crosshatching on the steels very well. I wonder where the new one is that I have? If it turns up I will post it up here. Here are some pics of the last used one that I have. $750 shipped in the US
