Overdrive?
Overdrive?
My neighbor says that there is an overdrive that can be added to the end of a T350 tranny. Does anyone know about this that can share their experiences? Pros/Cons? Price? Thanks!! :flag
Re: Overdrive? (1980ZZ4)
i think its called gear vendors....expensive...a friend has one in his 79 camaro...he paid somewhere around 1800 for it.. http://www.gearvendors.com/cg2wd3s.html
[Modified by pats406nitrovette, 9:00 PM 1/10/2002]
[Modified by pats406nitrovette, 9:01 PM 1/10/2002]
Ive heard about a Gear Vendors Under/overdrive unit which bolts on to an existing transmission wether its a auto or a manual, Its $2500 for the unit.
www.gearvendors.com
www.gearvendors.com
1980ZZ4,
I would rather see you go with a turbo700 with the 3.06 first and .70 4th gear.. It would be cheaper and easier to install!
Bob :cheers:
Bob :cheers:
Re: Overdrive? (Nailz)
Re: Overdrive? (parttime)
Not sure there would be enough room for the unit on these cars. It would at least require extensive crossmember mods. Better to swap to a 4spd O/D tranny like the 200R or the 700R.
Thanks to everyone for the information. I think I'll resort back to the 700R4. That was my first thoughts, but I didn't have any credible information and knowledge on this subject. Now I do thanks to you guys.
