strange pop??
strange pop??
I have got a new sound. as i back the car out of the driveway with the wheel turned to the left i hear a pop it only will hasppen once and i can feel it in the driverside floorboard. the carr did not used to make this sound. i have checked all the connections i can find. everything seems to be tight. the car will only make this sound when the wheels are turning left, and youre drive up or down a incline. im not for sure if you guys know the answer, but i figure you guys might be able to help me look in the right direction.
Re: strange pop?? (ykp53)
What size tires??
I went to a 255/60-15 all around, when I backed out of driveway, and the front wheels hit the bottom of the dip, I would here a POP sound.
On mine it is the tire hitting the fender lip at the same time the suspension moves. It happens very rarely. I just have to watch how far i turn and the angle I back out of driveway. I have moved since then and it does not happen any more.
I guess your just going to have to buy a new house :) :) :)
Good luck,
Good luck,
