How do I drain the oil from the Air/Cond Compressor
I have the compressor out of the car, How do I drain the oil out. Will be converting to 134
Re: How do I drain the oil from the Air/Cond Compressor (73-454)
Call a mechanic or an auto a/c shop and ask. My guess, the oil should come out of the big (suction) line.
[Modified by 71,454,4spd, 12:23 PM 1/10/2002]
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Re: How do I drain the oil from the Air/Cond Compressor (71,454,4spd)
Don't forget to replace the dryer/accumulator and expansion valve, too. ;)
Pick it up off the workbench, tilt it and dump the oil out of the compressor manifold area into a clean drainpan, so you can measure the amount of oil you remove. Suggest you meaure amount of oil you get out of old accumlulator also. You should install same amount of new oil as you remove.
