Removing Doors on a 79
Wish to remove the doors on my 79 for paint & body. Have electric windows/locks. Whats the best way to remove. Thinking I should remove the access plate,disconnect the plugs from the switches, and pull the wiring out of the door. But then I'll have a dangling wiring harness to contend with when I'm painting the jam. Any ideas appreciated. Thanks in advance.
Re: Removing Doors on a 79 (SteveA)
Best way is to leave the hinges on the door post,& remove hinge bolts from the door,easier to remove door that way,just slides off.
But first remove rubber conduit from the door,pull as much of the window/lock wiring as far into the interior of the car as you can,unfortunately the connectors are to big to pull through the rubber conduit.Use masking tape & newspaper to mask off the conduit & remaining wires.
I just painted the door surround & the door well & post, then put the door back on,realign all the gaps correctly,& painted the doors on the car.That way you will not damage the paint work when you refit the door.
Steve; I have found that it is much easier to realign the doors if you do not unbolt both hinges. I unbolted the top hinge from the door, but I removed the hinge pin from the bottom hinge. That way when you reinstall the door the height at the front is already correct. All you need to do is is adjust the top hinge to set the rear door gap. As far as the wire harness, I used aluminum foil and taped it to the masking paper that was covering the door opening. It is easy to apply and remove. Good Luck, Craig :chevy
