Need a good readily available chemical to brighten oxided aluminum intake
Looking for a good readily available, but not overly caustic or hazzardous product to clean the oxidation from a used Edelbrock Performer intake. Also, how about a suggestion who may carry this product and be able to find it locally. I would like to install the intake this weekend, and so hope to find a product that can work in a few hours or overnight without having to give it much of my attention.
Be Cool
"TEACH"
Be Cool
"TEACH"
Re: Need a good readily available chemical to brighten oxided aluminum intake (73 Teach's Pet)
Me too.
I just sandblasted, wire wheeled, and then polished a Z28 intake and it was a nasty job (wear a partical mask). I had to remove the heat shield and then re-attach it with 8-32 screws after tapping the holes. It looks better than new... not a single stain or flaw. I almost want to hang it on the wall as an art exhibit.
I wish I had a magic chemical too. But the only thing I've found so far that does an awesome job is elbow grease. :)
Re: Need a good readily available chemical to brighten oxided aluminum intake (Tom454)
Check out OEM paints website. I believe that they still sell an aluminum cleaner.
http://www.oempaints.com
Re: Need a good readily available chemical to brighten oxided aluminum intake (mulchie)
Yeh... I tried all of those cleaners... they leave a spotty, blemished finish that does not approximate the factory look, and cannot be polished very well because of the blemishes. They also do not remove deeply oxidized pits (which may not be an issue here).
I tried the chems.. I really did. I bought nearly all of them. Then I bought a sandblaster. No competition. Just trying to give you the benefit of my own wasted time & money. Not being a wise donkey.
St. Jude Donor '09
Yea, I've tried about everything at one time or another to clean aluminum intakes. You can never get them back to that "new" look. Anything that actually cleans them usually darkens the aluminum also :cheers:
I used to use Eagle MAg Wheel Cleaner on my Superram. It had phosphoric acid in it I beleive, and really brightens it up, it definitely doesn't turn it dark. It make it a little brighter or whiter than original though.
C6 the C5 of tomorrow
Plain old Lye ( draino) will strip off any oxidation and even anodizing. It does bring out the grain a little tho. And after your soak it neutralise it in a mild acid ( I use battery acid and water but Muratic or even vinegar might work ) this makes the black coating just wash off...
Re: Need a good readily available chemical to brighten oxided aluminum intake (427V8)
has anyone tried that oxyclean stuff thats on tv all the time... some body said they used it on their wheels and it took everything right off... not sure if works... just passing the info :jester
Re: Need a good readily available chemical to brighten oxided aluminum intake (ZD75blue)
I used Mothers Wheel Cleaner for gas stains on my intake.
Re: Need a good readily available chemical to brighten oxided aluminum intake (Paul 75 L82)
some time ago a guy on the forum recommended baking soda for the job......
Haven´t tried it so far, but probably someone else?
Re: Need a good readily available chemical to brighten oxided aluminum intake (454Big)
Tom454 is right...blasting is the way to go. You can take it to your local machine shop & they'll probably do it for less than $20. Its worth it. Unless the intake is almost spotless to begin with, wimpy chemicals like wheel cleaners will be a waste of your time & money.
Mark
Mark
see if there is a Trailmobile semi trailer dealer in your area. If there is get a product called "Trailer Brite" It is used to clean the rails on semi trailers that are oxidized. Really good stuff.
trower (12-31-2021)
Well,
Muratic acid is NOT the answer. I thought of using draino, but figured that stronger would be better....wrong. I mixed up the acid in a huge plastic storage container, double strength. Again, with the false logic stronger is better. My test piece was a really terribly oxidozed cracked up aluminum Vette valve cover I was given at a swap meet because nobody wanted it since it really was junk and only good for practicing aluminum welding repairs. The acid reacted with such intensity that it looked like an Alkaselzer. The valve cover was turned black. I thought maybe this was because of the heavy oxidation so I put in another mildly stained, but good aluminum valve cover. It too turned black and needed to be scoured with a scotch brite pad to remove the blackened coating. I'm glad I didn't soak the intake and screw it up, else I would have been doing a confessional on Bence's post about learning things the hardway. I don't think the intake will fit in my small blasting cabnet which is why that is not my first option. No one in our area sand blasts either.
I know that I saw a stand at Fall Carlisle with a guy selling a variety of products to remove aluminum oxidation, ranging from mild to intense, like I am looking for. Now I could kick myself for not buying some.
Still looking for the magic answer. Keep the great advice options coming in. I have another day to decide how to achieve my goal.
Many thanks to the folks who have chimed in with a number of options.
Be cool!
"TEACH"
Be cool!
"TEACH"
I don't know about using it as a cleaning chemical, but soda makes a dandy blasting medium for soft metals. It cuts like a knife thru paint & oxidization, but won't remove base metal, so it doesn't give aluminum a 'polished' look, just makes it look new.
Re: Need a good readily available chemical to brighten oxided aluminum intake (soundguy)
Sand blast the intake with something fine. Then clear-coat it. It will look great and clean easy.
Matt
Matt
Location: Godspeed Mikey Hogsmak Invitational Spring Skyline Drive Corvette Cruise
Cruise-In I Veteran
Cruise-In II Veteran
Teach, I had my brand new performer ceramic coated like they do headers. It looks great and will never oxidize, it only cost 100.00. by Airborne Coatings.
[Modified by 69shark, 11:25 PM 1/10/2002]
Re: Need a good readily available chemical to brighten oxided aluminum intake (Matt M)
I've always wondered about sandblasting or glassbeading the intake and then clear coating it. Does the regular clear coat hold up to the heat of the intake or is there a high temp clear coat available?
Cruise-In I Veteran
Re: Need a good readily available chemical to brighten oxided aluminum intake (bungoo2u)
Check out http://www.airborncoatings.com/
Look up a local foodservice chemical distributor........ie; Ecolab. They all have an aluminum cleaner which is phosphoric acid based. I sold these chemicals for ten years and used to use it on the aluminum rails on box trucks.....made the aluminum look like new with no pits or darkening. Do NOT use hydrochloric or muratic acid!!! :nono:
Oh.......and don't breathe the vapors either!!!
Good Luck
Good Luck
