What's this made out of?
St. Jude Donor '07
Just cut the dash to fit in a new radio and it took me TWO HOURS WITH A HACKSAW! I thought it was just plastic until I started cutting and found out it's not. Looks like steel cause it feels too heavy for aluminum.
Re: What's this made out of? (wombvette)
On my '75 it's not aluminum, it's a heavier metal than that. What my Dad used to call "pot metal". Probably one of the reasons it cracks so easy. Some sort of mix, and cast for sure, you can still see some rough edges along the mold seam.
[Modified by KenSny, 9:14 AM 1/9/2002]
Re: What's this made out of? (Paul 75 L82)
If that's the only place you've got to use your dremel cut-off wheel, then you must be one of those bastards^H^H^H^H^H^H^H^Hlucky people who didn't get a rustbucket 'vette ;) :cheers:
I go through cutoff wheels like the car goes through fuel... :smash:
Jim
Jim
St. Jude Donor '07
Re: What's this made out of? (KenSny)
It does kind of look a little scrappy on the unpainted side. Would make sense if it was just pot metal. No big deal, cd changer is in and sounds very good :yesnod: :cheers:
