Would u cut a hole in your original hood for a blower?
Re: Would u cut a hole in your original hood for a blower? (garagedweller2)
In a heartbeat! If I had the blower then the hood would just have to get over it. They'll let you drive race cars at 13. That gives you 5 years you don't have to drive the hauler to get there. :D
St. Jude Donor '09
Sure, I already cut up the original when I molded on the L88 scoop.
That way at least I knew I was sarting with a perfect fitting hood :yesnod:
[Modified by yellow 72, 9:36 AM 1/9/2002]
Re: Would u cut a hole in your original hood for a blower? (yellow 72)
No, I would mount a centrifugal blower under the hood! :)
[Modified by Matt M, 3:50 AM 1/9/2002]
Re: Would u cut a hole in your original hood for a blower? (Matt M)
Nice Blower matt m
the hoods are not marked for a particular year and VIN right or wrong?
would you do it to an all original #'s matching car?
[Modified by garagedweller2, 4:49 AM 1/9/2002]
YES! Plan to someday.
My question is, which adds more HP, your typical Weiland type supercharger, or a centrifugal like mattm has??
Already Done That :D I'm still waiting to get a Blower :yesnod: For now a Tunnel Ram will have to do :cool: :cheers:
Re: Would u cut a hole in your original hood for a blower? (Monkeywrench)
My car's original hood came with a hole cut in it for the tunnel ram that was there. So I took another hood and got a highrise after my aircleaner didn't fit the stock w/ the new motor.
Received 1,468 Likes
Cruise-In II Veteran
Nope. Never. To begin with, blowers do not interest me, but if I was going to run one, I'd cut the hole in an aftermarket hood.
Re: Would u cut a hole in your original hood for a blower? (ylose)
Ylose the tunnelram was gone before I got the car otherwise it may have still been on the car ;) .
Re: Would u cut a hole in your original hood for a blower? (SmokedTires)
Re: Would u cut a hole in your original hood for a blower? (QuickVet)
yes, but if i had money for another hood i would buy one and use that one for the cutting:)
