How did you install your dual spals
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
Re: How did you install your dual spals (71DropTop)
Here's How... http://forums.corvetteforum.com/zerothread?id=173121
And the pics are here.... http://community.webshots.com/album/27554540PUOdIkdsvs
I submitted this as a tech tip... but noting ever happened!!???
Either Way good luck with the install! Your gonna love em!:cool:
HEY TOM DeWitt..... Did I tell you these C3 Guys would Come around or What???? :lol: :p:
[Modified by Mike69, 7:32 PM 1/8/2002]
You didnt mention what kind of radaitor you are using. If you have an aluminum rad you can get this kit from becool. It uses four mounts as shown in the picture so you do not have to put anything through the radiator. They were a bit pricey, but nothings to good for my 71.
If you are using a stock rad, I would just go to the parts store and get nylon bolts made for this and slide them right through the rad core. I used these type bolts to mount the tranny cooler to my 81 2 years ago and have had no problems.
Good luck,
[Modified by dennisr, 6:53 PM 1/8/2002]
Good luck,
Re: How did you install your dual spals (Mike69)
I'm still waiting for mines to come. Now that was some awesome detailed info! Thanks!!! :cheers: :cheers: :cheers:
Re: How did you install your dual spals (dennisr)
My 71 is a BB with griffin radiator in the 27.5 core so i need those type of brackets from becool Thanks everybody for the info :cheers: :cheers:
