Front Panel seperating Just behind the front Light Lids
The panel behind the front light lids has seperated from the steel support. Which is the best Adhesive to re-glue.
Re: Front Panel seperating Just behind the front Light Lids (73-454)
i would think epoxy... but thats just me... unless you want to be able to pull the support later, not sure what they used stock up there
ZD :seeya
ZD :seeya
a lot of the earlier cars, chrome bumper, were riveted and a very common problem when they start to seperate, quite often u can see the outline of rivets pulling thru.
have drilled thru from top and rerevited with stainless rivets as the original mild steel ones rust out.
unfortunately can be a bit of a major repair.
