Noticed my neutral idle was low... car stalled idling in reverse.
Weirdness today. I turned my car on for the umpteenth time (just got off the freeway, drove a couple blocks at 40 mph, parked, came back in 45 minutes or so and the car stalled when I put it in reverse and let off the brake.) Is this generally a carb worry? Also, I have kind of a very fast ticking noise, and I'm not sure if it's a spark plug wire or a lifter(I checked the right bank where the noise seems to be coming from, and there's no sign of burnt or loose wires.) Could either of these be a reason to suspect my carb? I guess I might have to send it off to Lars sooner than I expected.
-Steve
-Steve
Re: Noticed my neutral idle was low... car stalled idling in reverse. (Pacin'California)
That ticking could mean a burnt gasket on one of the exhaust manifolds. May have to replace one or more of these gaskets (no biggie...I've done it myself a few times).
As for the stalling in reverse...I too had that problem...I rebuilt the carb and it seemed to help immensely. Was it particularly cold that day you were driving? I doubt it from where you live...but otherwise, it could just be a carb issue.
Good luck! :seeya
Good luck! :seeya
Re: Noticed my neutral idle was low... car stalled idling in reverse. (78RedShark)
It was in the 50's. The car was much harder to start back up than it usually is, starter cranked at least five times when it usually turns over in less than one crank.
-Steve
-Steve
I was thinking could also be a vacuum issue.
Check your idle...may need a slight adjustment up, because may not be generating enough vacuum.
Regards,
Rob
[Modified by 78RedShark, 4:19 PM 1/8/2002]
Regards,
Rob
I have the exact same problem. The ticking sound is coming from your manifold, the gasket is leaking. It will tick faster as your rpms go up..etc etc and you'll notice a performance drop. I had the great grace of fixing up my right manifold gasket only to find the next week the left manifold gasket had begun to fail as well. I'm going to tackle that problem myself. $350-400 dollars a manifold just doesn't work for a 18yr college student. Anyone have any experience fixing the gasket on the left manifold? I would love to hear some tips or how to's. Thanks in Advance!
Re: Noticed my neutral idle was low... car stalled idling in reverse. (Phoenix79)
I have, Phoenix. Actually, I had the same problem in reverse. My left manifold needed all the gaskets replaced...it was relatively easy to do...NOT. The bloody heat shield surrounding the manifold had to be taken out...the one that connected to the original air filter...i've since replaced that with a K&N open air filter...but that heat shield was a PITA to remove...I had to actually cut it out with pliers and pure will...I didn't need it anymore anyways.
But after that, it was just a matter of loosening the bolts and sliding the gaskets in through the top. They were very cheap (about $10 Cdn. for the set).
Once I did that, the right side gaskets needed replacing! But that's a bit harder...but I have to first remove the ECE...it's bolted right onto the exhaust manifold...and it's on TIGHT!
It's just a matter of loosening the bolts enough to pull the exhaust manifold back enough to be able to slide in the new gaskets.
Good Luck :cheers:
[Modified by 78RedShark, 9:34 PM 1/8/2002]
[Modified by 78RedShark, 9:35 PM 1/8/2002]
Good Luck :cheers:
Cruise-In VI Veteran
Cruise-In VII Veteran
I just pulled the exhaust manifolds off my car for a head swap, and they were assembled without gaskets. Plus one bolt was missing, I never heard any sort of noise from the manifolds.
I think that the SB ram's horn manifolds were assembled from the factory without gaskets. I'm wondering if I should go back with gaskets or just put it back like it was?
Re: Noticed my neutral idle was low... car stalled idling in reverse. (Smokehouse69)
Thanks for the info, I really appreciate it. The leaking manifold gaskets are the last of the major problems with my car...well that and my left muffler is basically BROKEN, but I have some flowmasters coming on soon. With the help of some friends, I'm going to tackle the manifold problem this weekend and hopefully it'll end the leaking for a long time. You know what, your 78 looks exactly like my 79 except my interior is saddle.
Beautiful car, looks very well taken care of :yesnod: Thanks again!
Thanks Phoenix...let me know when you post a pic of yours.
Later! :cheers:
Later! :cheers:
