Steering box grease question?????
I thought it had been discussed here before but could not find it in the archives. What is the best grease to use in the steering box?
Thanks in advance, George
Re: Steering box grease question????? (999)
Mercedes Benz Chassis grease. Sticky stuff, only available through Mercedes dealerships (go along and give some money for the coffee to the mech´s....:D and take a small can with you......)
I used Mobile 1 synthetic chassis grease, got it from Autozone. Don't fill the opening completely, leave a little room for expansion.
A good lithium based ball joint grease is recommended. GM dealers can obtain Chassis Lube #12377985. Just be careful, the part number is for a case of 10 tubes. You only need one tube for the gear.
As mentioned previously, don't overfill the gear. You need some air pockets inside to allow for expansion of the grease because of normal underhood temperatures.
Re: Steering box grease question????? (Jim Shea)
Jim is right on. I over-filled mine last summer with chassis grease and it leaked a bit. I took some out and problem gone. What prompted this was a post to just test the level. Well, there was no level. The box was dry or congealed. Check it for safety's sake.
