Mounting dual 12" Flex a lites electric fans... ?
Old 01-07-2002, 07:42 PM
Bans25
Bans25's Avatar
Default Mounting dual 12" Flex a lites electric fans... ?
Hi all,
For those who have dual 12" Flex a lites... How did you mount them to the
radiator?
thanks
-Bill
Old 01-07-2002, 09:12 PM
nastee383
nastee383's Avatar
Default Re: Mounting dual 12" Flex a lites electric fans... ? (Bans25)
With the "through the radiator" fasteners they supply which I have heard is not good. I may fab up some brackets. The ones they supply won't mount on a Vette.
Old 01-07-2002, 09:14 PM
427V8
C6 the C5 of tomorrow
Support Corvetteforum!
427V8's Avatar
Default Re: Mounting dual 12" Flex a lites electric fans... ? (nastee383)
I used their brackets and drilled four holes in the top and bottom of the radiator. Works like a charm!
Old 01-07-2002, 09:38 PM
INTIMIDATOR ZO6
INTIMIDATOR ZO6's Avatar
They work just fine :D
Old 01-08-2002, 12:40 AM
Carl in LA
Carl in LA's Avatar
Default Re: Mounting dual 12" Flex a lites electric fans... ? (Intimidator454)
Done it both ways... did through the radiator on the old stock one and now I have the brackets screwed into the frame of a beautiful new Griffin!
BTW - The Flex did not fit easily onto the Griffin universial 31x19.
Intimidator454 - Do you really run Flexilites with that monster engine??? Dosen't Flexilite recommend 220 hp and under?
Old 01-08-2002, 06:29 AM
1979toy
1979toy's Avatar
I used the Flex-a-Lite brackets. To the radiator support bolts at the top and trimmed the lower brackets to fit the area between the radiator and support.
Old 01-08-2002, 10:26 AM
paso
paso's Avatar
Default Re: Mounting dual 12" Flex a lites electric fans... ? (1979toy)
That's exactly what I did works and looks good.:)
Old 01-08-2002, 02:53 PM
MikeT
MikeT's Avatar
Default Re: Mounting dual 12" Flex a lites electric fans... ? (paso)
I used their brackets as well. Took some small modifications to the bottom but that was easy!!!! Very happy with them too!!!!
Mike
Old 01-08-2002, 04:27 PM
Brutus
Brutus's Avatar
Default Re: Mounting dual 12" Flex a lites electric fans... ? (MikeT)
Same here with mine. Cut and modified their brackets, drilled a hole or two. Easy.
Old 01-08-2002, 09:38 PM
nastee383
nastee383's Avatar
Default Re: Mounting dual 12" Flex a lites electric fans... ? (Brutus)
Could one of you guys that modified the brackets please post or email a photo(s) to me. I would like to do away with the thru the radiator fastners. Thanks
Old 01-09-2002, 10:48 PM
blu73
blu73's Avatar
I submitted a "Tech Tip" that included some line drawings of adapters that I came up with to mount the fan to the stock radiator without drilling any holes in the radiator at all. The stock radiator in our '73 has a channel at the top and bottom that I was able to use. The plastic blocks that I used slip into the channel, then the fan bolts to the adapter blocks. E-mail me if you have any questions about the blocks. I'm not sure how well the drawings look within the "Tech Tips" area. My computer isn't the greatest.
Old 01-09-2002, 11:24 PM
Brutus
Brutus's Avatar
Nastee383...I'll see what I can come up with for you.
To Mounting dual 12" Flex a lites electric fans... ?
Quick Reply: Mounting dual 12" Flex a lites electric fans... ?
