Wiper Dood Vac Help
Wiper Dood Vac Help
After Installing the wiper door and all the missing parts as in the AIM they don’t work. The headlight also won’t open. But if I block off the two lines going to the wiper actuator the headlights will open. Any body have any idea what the problem is.
Re: Wiper Dood Vac Help (je68)
I am trying to figure out if you have it plumbed incorrectly or if you have a vacuum leak close to the wiper actuator... MJ
[Modified by MNJack, 12:47 AM 1/7/2002]
Re: Wiper Dood Vac Help (Ed T)
I assume you mean that you have to plug the 2 large vacuum lines that connect to the 2 ports on the wiper vacuum canister in order to get the headlights to work. If that's the case, you've got a big leak in the wiper vacuum canister on the firewall. There's not enough vacuum being maintained in the system to actuate the lights.
Do you have the early (cylindrical can) or late (2 pie tins) 68 wiper canister?
Gary
Gary
Re: Wiper Dood Vac Help (Garys '68)
Gary
Gary
No I have the two lines that come from the drivers side one big and one small that attach to the actuator valve
