Any other vendor for rear end parts (posi)?
I have a cracked posi case...any one else besides "Toms Differentials" selling new or used? If you have a web address or phone #, I could use it. Thanks, Deen. (Gotta compare prices :yesnod: )
Re: Any other vendor for rear end parts (posi)? (DeenHylton)
I can't help you for parts, but by posi case, do you mean the outer bell shaped shell, or the carrier assy frame that has the spyder gears, clutches, and ring gear tied on??? certainly not the rear cover, which is very common to crack/break.....???
GENE
GENE
Re: Any other vendor for rear end parts (mrvette)
What series case are you looking for. A 3 series case any used Corvette parts place should have one. I just got a 4 series case from a used parts guy in Pittsburgh. Harvey Jacobs 412 264 9151. I got the case and 2 days later broke the 4.11 gears so I have a case that is not being used. I went with 3.70 since I already had that rear
Re: Any other vendor for rear end parts (Gordonm)
Mrvette: yes I am talking about the carrier assembly...and I think I have found a few. As for the cover, I may be wrong but I thought they normally crack in the spring pad area and not from dragstrip abuse...anyone else shed some light on this???
Gordonm: Thanks for the tip...I'll call "Harvey Jacobs" today and see what he's got. I have found 3 otheres which are all priced reasonable
