More stupid shock questions
Well, I installed the shocks and went with the three retainer set up.
Two things:
1. The Assembly manual calls for 120-180 lbs on the lower shock mounts. I set my torque wrench for 150 lbs. but seemed to pass a point where the bolts just felt like they were spinning. I stopped and said to myself, not another turn until I check with the C3 board. What's up, is 150 lbs correct? Should I just keep torque-ing?
2. The top nut the shock came with is called a "lockable nut, " I think. It seems to have a small plastic ring inside it towards the top of it. The only papers the shocks come with mention that it should nit be used more than once. So I figure once it tightens it starts to set grooves in the plastic and down it goes. But, it won't seem to break the plastic. It just keeps spinning and won't go any further down the rod. What am I missing here?
Thanks,
B-L88
Two things:
Thanks,
B-L88
Re: More stupid shock questions (BAD-L88)
Regards,
