HD Idler arm, how to identify?
Hey guys and gals,
The last weekend of my mid-winters vacation I'm fitting back up all those cleaned and rebushed a-arms with new ball joints. I got the vette brakes anti-bump steer blocks installed on the steering arms(not an easy job).
My question is, the idler arm coming off has 2 castelated nuts. The mounting arm is threaded and is nutted/cotter pinned to the arm. Now the one I got new to install has a fitted mounting arm. Which is the "heavier duty" unit? Or are they both comparable in strength?
Thanks Scott
Thanks Scott
Re: HD Idler arm, how to identify? (Scott78)
Typically the HD idler will have a nut at each end of the idler arm - one where it attaches to the relay rod and the other where the arm attaches to the mount.
They may vary by MFR though...
Re: HD Idler arm, how to identify? (fauxrs)
Thanks Fauxrs,
The old one was still real tight , but I'll put the one in that came with the Zip kit. If it fails fast then you'll hear me yell :yesnod:
Scott
Scott
