Where to get correct PS pump bracket and alternator bracket??
I think i might need to get a new set of brackets since they seem to be bent to fit properly and considering i need even more alignment. I need the alignment for new pulleys im installing, Just think itd be a good idea to start from the correct pulleys since these are already bent.
I need them for a 74 small block with headers?
Thanks Chris
Thanks Chris
Re: Where to get correct PS pump bracket and alternator bracket?? (74VETTE)
Chris
Summit, Jegs and probably your local hot rod shop has a left side, header mount altternator bracket with 1 in fore and aft adjustment. From your earlier thread where you shimmed the mount with 3 washers on the PS, why not shim behind the pulley?
