I was getting bored...
I can't find anything else that my car needs so I decided to start detailing underneath. Ever try to wash down the bottom of a car two feet above your head with a towel soaked in varsol? It sure feels good running down your arms to your armpits....well I guess I said I was bored.
[Modified by Binnie77, 7:46 PM 1/3/2002]
Re: I was getting bored... (Binnie77)
WOW, I think that helps with my big decision. The lawn tractor comes out of the garage and the Vette goes in. I need to get it going......
[QUOTE]I can't find anything else that my car needs. . . [QUOTE]
Congratulations, you have the rarest C3 of them all and I WANT IT! :lol:
Seriously though, it is looking really good under there! Keep up the good work. :cool:
Re: I was getting bored... (81vette)
Looks good! What did it look like before the wash?
Mark
Mark
Great looking job binnie:) what is the # the factory wrote on the passenger floor pan you can see in the picture. I know awhile back that Juliet was asking people with 70 cars so they could use it for some NCRS stuff. Mine is still legible so iI could compare FWIW.
Re: I was getting bored... (paso)
The last three #'s in your Vin is not those three #'s is it? We could probably ask Juliet what the out come of her sleuthing was re: those #'s. must be some meaning to the production workers.
Re: I was getting bored... (BigBlockVette)
Looks Great!! But what is varsol? I might need to get some come spring.
Dwayne
Dwayne
Varsol is a common solvent used for cleaning engine parts and degreasing. Is Varsol a Canadian trade product? I assumed it was common everywhere.
Re: I was getting bored... (427_Roadster)
Very :cool: looking!!!
You gotta post more info on those ramps of yours!
:cheers:
-Tom
:cheers:
-Tom
Both sections are built identical. The ramps are 10'9" in length. You can construct them from 2"x10" or 2"x12". In this set I used 2"x10" and then nailed a couple of lengths of 1"x6" on each side on the bottom to give some extra lateral support. The top and bottom are 2"x10" with 2"X10" uprights on 16" centers. You will need 2 sheets of 1/2" plywood or waferboard for the sides. Cut each sheet of plywood into 3 strips 16" wide. It will take one sheet per ramp. Use 2 1/2" spiral nails on the side pieces. Use 3 1/2" spiral on the framework. On the ends where the car comes up, spike another piece of 2" x 10" to support the planks for driving the car up on. These 2 planks only need to be about 7' long with a couple supports under them. With that short a length my side pipes still clear fine. I am going to mount a couple of permanent lights and a 110v receptacle on the inner sides of the supports. If you have a good level floor they will be very stable and will support a bulldozer.
[Modified by Binnie77, 9:42 PM 1/3/2002]
