Rear Calipers too big
OK - for those of you falling the saga. I was finally able to bleed my rear calipers but here is the kicker. When I put my wheels back on I found the outside of the caliper did not clear my Cragar SS. Upon further inspection I found the caliper is quite a but wider than the old one. They are both AC/Delco castings however the new one protudes further out where the pistons are. I will try to get some photos up shortly.
I already have spacers on the rear to accommodate the Cragars and think I should put any more on. Has anyone seen this before?
Thanks in advance,
Thanks in advance,
Re: Rear Calipers too big (Scott A)
How did you space it out?
Re: Rear Calipers too big (gkull)
These were already installed when I bought the car - when I go out take some pics I will measure the spacers.
Thanks again
Thanks again
St. Jude Donor '09
I rode this ride when I inquired about the American CP-200 wheels, I sales rep from Jegs told me he tried to put them on a 72 and the calipers wouldn't clear.
Others said no problem. Turns out as you discovered there are at least two different size Delco calipers :cheers:
You sure you don't have a front caliper mounted in the rear, I THINK the mounting bolts/mount pattern is the same, so it will fit, but in fact the rears are allways smaller bores and smaller size caliper externally....
GENE
GENE
Re: Rear Calipers too big (mrvette)
My wife asked the same question. However, by looking at the bleeder config - there are 3 on the rears and only one on the fronts. After she asked I had to do a double take myself. Upon further inspection of the old and new calipers it appears that there are at least two different Delco castings.
1965-Early 1967
5465954 (front, inner)
5465952 (front, outer)
5465902 (rear. inner)
5465905 (rear, outer)
Late 1967-Early 1972
5452270 (front, inner)
5452273 (front, outer)
5452281 (rear, inner)
5452284 (rear, outer)
Late 1972-1982
5473795 (front, inner)
5473796 (front, outer)
5473806 (rear, inner)
5473807 (rear, outer)
While there are some subtle differences between them, I had never heard that one caliper type was physically larger than the others. Anything is possible though... What are the casting numbers?
Regards,
when i have put my cragar on my vette i had the same problem maybe the previous owner did what the shop suggested me :grind off some metal from the caliper.they told me that they were doing it often.but I've just used a larger spacer as my tires were also too close to the trailing arm.
Re: Rear Calipers too big (zzrck)
Thanks everyone who replied. This place rocks!! I will get the casting numbers tomorrow. However, these are brand new delco castings from Ecklers, so I don't know if they will fall in the list.
