slam the seat??
slam the seat??
anyof you tall guys, or arthritic types ever lower the driver's seat in a shark....????
as in REALLY lower the thing....I knock the two back mounting brackets off the tracks, and bent the front tabs to lower that by a little bit also...
gained maybe an inch, but I need more...much more another 2-3 inches would be grand....any ideas???
is there anything in the seat frame??? how about mods to the floorboards..???
I allready moved lower firewall forward about 2.5 inches or so, and pedals too...that will give me more critical leg room, lower my knees a bit...
moved wheel assy back toward me only 3/4 inch off the firewall, wish I could do more....just not there in stock bracketing....anyone else have any ideas...??? maybe I should get a buddy to relocate/weld bracket on the steering columb...???
GENE
GENE
Re: slam the seat?? (Chris Fowler '80)
I have to agree, at 5'7 I fit very comfortably in my C3. I know that doesn't help you much, but there might be a little more room in a C4 or C5 for tall guys, if you continue to see a Vette in your future. Good Luck :D
Re: slam the seat?? (Warp70)
quote:
Well there is one advantage of being short. I fit fine
:cheers: :cheers: :cheers: :cheers: :cheers:
5'6"..no problems here :D
Nope, I gave up on an '87 in favor of the better seating in my '72 here, and now I need even more room......there are many more reasons for the change also, but seating was one consideration...
I guess I will have to cut seat frame and reweld it all around....
GENE
GENE
Re: slam the seat?? (jonvolk)
Re: slam the seat?? (mrvette)
Yea You should see me get in mine too. :) :) :) I'm only 5'3" Actually I thought that I would be too short for one until I drove mine and it's great.
Re: slam the seat?? (Ed T)
You know in the car biz they say 'there is an butt for every seat'....well my butt fits my seat very well, only thing is, after looking at it again just now. I guess I will cut out the floorboard, take out the seatbelt plate, have a buddy reweld it to lower the belt assy, and reseal that plate onto the cut out glass section....lowering the belt mechanism by about 2 inches....
now to do same to front of seat by about an inch or so....
using a fair amount of construction adhesive to seal it up....and or fiberglass.......
gee all I need is another project....
GENE
GENE
A note to the "height challenged" drivers........when I took my rusted seats apart I found that bubba had made up 4/ 2" spacers out of washers between the tracks & seat frame. It woulda been a good idea if he had used hardened hardware.
Re: slam the seat?? (Silvr77)
I dunno there is something to be said for those HUGE 60-40 Caddy seats out of the 70's...leather, tall enough, adjustable headrests, electric everything....fit anyone form a 4 1/2 foot gal to a 6 1/2 foot guy really easy, with good visability too....and too boot the mechanisms rarely gave much troubles....damn things had nearly 5-6" worth of vertical and nearly 9" of horizontal travel on them....never been equalled since then...even the new 'large' caddy's....
GENE
GENE
Ed, tell you what, IF I ever get this car back together, it's a miracle at this point....I got so much poopie torn apart, I dunno....well a bit along....
so I might as well trash the seat area too, nothing else to loose, think I"m going to get a whole bunch of thing welded up for it...
including dropping the seat front...and rear too....I"m looking at that frame and thinking, wonder if it's that big a deal to mount the seat rear onto the frame instead of the body directly.....hard choice, don't need any more harsh a ride....
GENE
GENE
