Great article about flat tappet vs. roller cams
Check it out if you're into that sorta' stuff: http://www.72chevelle.com/lashword.htm
Re: Great article about flat tappet vs. roller cams (Flareside)
It doesn't point out that solid rollers are even better.
Re: Great article about flat tappet vs. roller cams (gkull)
I believe the roller they used is a solid roller. Look at the chart at the bottom of the 4'th page, they lashed the roller cam at .020 instead of 1/4 turn like you would a hydrolic.
Re: Great article about flat tappet vs. roller cams (Chris A)
Chris - I hate comp cams web site :mad :mad :mad
You can't look up the part number given in the article - It just says give them a call then you have sit and wait through page after page of BB cams. I sent them e-mail 2 years ago that their site sucks. Before I was trying to get info on a custom made to my specs solid roller cam with sleeved gear.
I got out of the article that it was a H-Roller :confused:
For what it is worth,I still only run roller lifters in motors with more than 270@0.50. Man I gotta tell you the extra HP verses the reliability just is not worth it. A little of the old with some of he new goes along way.
edited to add:
I am not going to run 5/30 in any motor I build! you guys that like 3n1oil go ahead!
[Modified by mountainmotor, 12:27 PM 1/2/2002]
edited to add:
