Fan problems..the darn shroud is warped, need a recommendation!
Re: Fan problems..the darn shroud is warped, need a recommendation! (JRChurch)
Also check to make sure your motor and tranny mounts are Okay. If they are worn or broken it can **** your engine enough to cause shroud interference. And check to make sure the shroud is mounted properly just in case.
.02$
.02$
