TIMKEN bearings “Tech Tips”
Old 01-01-2002, 01:59 PM
MIKER
MIKER's Avatar
Default TIMKEN bearings “Tech Tips”
This information may not be needed by many of the Corvette Forum members but I found it to be a good refresher so I’m passing it along. I don’t know about you guys but “I” have always had a bad habit of neglecting the wheel bearings on all of my vehicles.
I’m currently rebuilding one of my rear wheel bearing assemblies . . .((and, it’s a REALLY slow day here at work!))
TIMKEN bearings http://www.timken.com/
TIMKEN bearings “Tech Tips” http://www.timken.com/products/bearings/techtips.asp
Here are just a few of the topics covered on the “Tech Tips” web site.
-How do you rate on bearing adjustment?
-Why Oscillate or rotate a bearing?
-How nut torquing and back-off are used to set wheel bearings
-Proper Heating and Freezing Practices when installing press-fit cones or cups
-Preload in Wheel Bearings
-Maintenance Practices
[Modified by MIKER, 12:09 PM 1/1/2002]
Old 01-01-2002, 03:17 PM
Gordonm
Gordonm's Avatar
Default Re: TIMKEN bearings “Tech Tips” (MIKER)
Wheel bearings are one of those things that get neglected. If they are working most people leave them alone. You don't think about it until its to late. Good info there
[Modified by Gordonm, 2:18 PM 1/1/2002]
Old 01-01-2002, 07:10 PM
popmuzik
popmuzik's Avatar
Just had ours checked ...the car still had the original bearings and seals! And now to have a rear spindle replaced.....
To TIMKEN bearings “Tech Tips”
Quick Reply: TIMKEN bearings “Tech Tips”
