Silicone brake fluid: Long term use
Received 6,529 Likes
C2 of Year Finalist (track prepared) 2019
A couple of decades ago I put some new wheel cylinders on my '60 and filled the system with silicone brake fluid. For 20+ years the brake system has worked and worked and worked with no maintenance or attention.
Well, this week, as part of a project to install Big(ger) Brakes on my '60, I removed those 20 year old wheel cylinders. Out of curiosity, I popped them apart to see how they had fared with 21 years of use.
The two photos below tell all.
Looking into the bore of one front wheel cylinder:
The interior parts of the same front wheel cylinder:
Yep, shiny metal everywhere. Not one bit of corrosion anywhere.
The wheel cylinders I pulled off back in '87 had had only glycol brake fluid and they weren't even rebuildable.
So if you've ever wondered if you made a good decision when you decided to use DOT 5 fluid, here's some evidence that you did.
Jim
Jim
Received 1,843 Likes
Jim:
If your post/pictures don't make a believe out of the doubters, nothing will.
Jim:
If your post/pictures don't make believers out of the doubters, nothing will.
Excellent report!
I switched to Dot 5 in my '65 roadster back in the 90s and have had no problems at all. The pedal has always been rock solid and the peace of mind about paint damage is icing on the cake.
You have made me think seriously about getting rid of the Dot 3 & 4 in two of my other old cars.
I installed SS sleeved calipers on my 67 in 1982 (26 years ago!!) and used Silicone Brake Fluid, DOT 5. To this day I have never touched them again, and they continue to work flawlessly. DOT 5 is truly the way to go!
I put silicone brake fluid in my 69 Road Runner in 1989. I've never had any brake problems in the 19 years it's been used. I put it in my 65 Corvette about seven years ago, no problems with it.
Received 4,553 Likes
2021 C8 of the Year Finalist Unmodified
2019 C1 of Year Winner (performance mods)
2017 Corvette of the Year Finalist
2016 C2 of Year
2015 C3 of Year Finalist
That is an interesting post. I have Silicone in one of my cars and have never had a problem I may convert the others. You can't argue with those pictures. The silicone fluid just doesn't attract moisture like the others. It's a nice option for these old cars that sit alot.
My DOT 5 fluid has been in for almost 20 years. I changed all 4 calipers and installed silicone
fluid back in 1989---NO PROBLEMS YET !!!
RON
I second all the opinions about the goodness of silicone brake fluid. It's been in my 67 for five years with no problems. Yes, it can attract air, but that's what bleeding the brakes if for... and the hardware will always look new..... and you will never destroy any paint either.
Need help understanding the advantage/disadvantages of Silcone vs. DOT 4 synthetic.
1) As I understand, in order to change from DOT 3 / 4 to DOT 5 one needs to ensure ALL previous completely cleaned out. Also must rebuild Master Cylinder and Wheel Cylinders......
vs.
Just blowing out old DOT 3 / 4 and changing to say DOT 4 synthetic?
2) DOT 5 silicone will not absorb moisture when classic may sit.
vs.
DOT 4 synthetic that will also not absorb moisture when sitting?
I know I'm missing something as to why I'd want to change from DOT 4 synthetic to DOT 5 silicone?
Also, does anyone have procedure and photos showing what is entailed with Mast Cylinder rebuild?
Thanks in Advance,
RK
vs.
vs.
Thanks in Advance,
RK
Thanks for the confirmation of the brake job I did to my 65 back in 82.Every time I drive the car, which is rare, I wonder about the Silicone I replaced back then. This is very comforting and informing.
Thanks
Thanks
The only thing you're missing is clicking on the "search" button, same subject.
[QUOTE=RoadKing96;1566662905]Need help understanding the advantage/disadvantages of Silcone vs. DOT 4 synthetic.
