CARB SIZE FOR BIG BLOCK
I BUILDING A 454 FOR MY 69 VETTE,4 SPEED WITH A MILD CAM. WHAT SIZE OF CARB WOULD WORK??? :crazy: :crazy: VAC SEC OR DP??? :seeya
Re: CARB SIZE FOR BIG BLOCK (Pacin'California)
750 cfm for a "mild" motor. Vac sec/ or double pumpers, well, that's a personal decision, I think. :)
-Steve
-Steve
Re: CARB SIZE FOR BIG BLOCK (RUDY S)
Can you give me some of the details on the engine that you're building? My matching numbers 427 has lost alot of its performance and I'm thinking of storing it and putting in a crate motor or possibly building a 454.
Re: CARB SIZE FOR BIG BLOCK (zwede)
Don't over carb. So many people like to recommend huge carbs for street. I have seen recs for 950 Demon carbs on this forum before! :rolleyes:
Someone posted a formula you can use. I think it is on the Holley site as well. This formula uses displacement, rpm, and volumetric efficiency to determine carb size. When I ran my 427 through with 80% effeciency, it came back with 700cfm and 80% is probably optimistic at that.
Right now I am running a 600cfm Holley double-pumper on my 427 and it works great. No loss of power at upper rpm at all. The response (metering signal) is awsome.
