where to buy worm gear for odometer
I have my 70 coupe odometer apart. Worm gear that meshes with main drive on speedo seems worn. Where is the best place to get a new one, preferably metal?
Many thanks to daily driver for his excellent post on how to disassemble without removing speedo needle.
Re: where to buy worm gear for odometer (bhawk)
local speedometer shop should be able to help you. If not go to salvage yard and look at old speedo out of any GM and see if they will work. :cheers:
This is out of my parts box from the '69 speedo...
If it's the one you need, I can drop it in the mail to you, no charge. It doesn't seem worn at all.
If you needed the other worm gear-the one at the bottom/back of the unit, mine was also worn badly also, can't help you there.
Let me know...
:cheers:
-Tom
Let me know...
:cheers:
-Tom
