Optispark Post Mortum, '94 LT1 , 59,800 miles
This is what I found when I opened up my failing Optispark on my '94 LT1. This Opti was working at the time of removal, however I had symtoms of Lurching at idle and irratic acceleration. I stopped driving the car 2 days after these symptoms appeared, especially when I noticed that they were getting worse very quickly. This was the original Opti. One thing I forgot to mention in the pic is that all the inverse torx bolts that hold this thing together were almost finger tight.....
De-gutted Optispark:
And here is a close up of the optical wheel and Mitsubishi Optical sensor.
And here is the WP bearings that led to this whole mess :
Al Borman (07-30-2016)
St. Jude Donor '05-'06
Typical. Actually that is a bushing not bearings and is one source of ingress.That is one thing the Dynaspark and MSD changed to bearings. From the rust and moisture your sensor probably had a coating on it too. The nitrite seal is a known weak spot too which is why I always suggest a good bead of sealer around the cap.I bet it failed because the sensor is blind.You also see the crappy seal around where the plug goes through the cover here too.
One other thing to look for is "carbon tracing" on the top of the optical sensor plastic cover Once that occurs it will misfire it may be hard to see but the firing may cross over due to HEI following the trace. One reason that just changing cap and rotor may not help as the sensor cover does not come with them and if traced will still miss.
[QUOTE=MikeC4;1566572994]This is what I found when I opened up my failing Optispark on my '94 LT1. This Opti was working at the time of removal, however I had symtoms of Lurching at idle and irratic acceleration. I stopped driving the car 2 days after these symptoms appeared, especially when I noticed that they were getting worse very quickly. This was the original Opti. One thing I forgot to mention in the pic is that all the inverse torx bolts that hold this thing together were almost finger tight.....
Can you please explain your "lurching at idle"?
Do you mean your tach would go up and down 50-100 rpm while stopped and in gear?
Thanks
Thanks
Yes, the RPM's would jump 100-200 and it was like the car was momentarily accelerating. When I was at a stop, I made sure I had more than normal pressure on the brake pedal....The car would ...like....jump. Same thing if car was in Park or Drive.
Also, on exiting the car, a faint smell of coolant led me down the path to the Opti, as no error codes were set....
Interesting.
If it was mine, I would put compressed air to it and reassemble it (and a nylon toothbrush on the metallic parts). I imagine it could be used for testing since no parts of it look wasted. If it has a bushing, and not bearings, I wouldn't even think twice about it...
My
My
I started seeing these symptoms today. The car has only 41,000 miles on it and I know I've never got the optispark wet. I guess a waterpump can go bad that fast.
Wow, I lucked out. My water pump was just starting to drip from the weep hole, and when I openned up the opti to replace the cap & rotor, the seal was cracked and crumbled in my hand but the insides had no rust, corrosion, or visible damage of any kind. The cap showed its age where the rotor makes contact (don't recall the name for those little metal contacts), but it was not as bad as I expected it to be. Especially since it was not vented. I must have caught it in time.
I'm thinking I may turn my old opti into a clock for laughs.
Location: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
MikeC4,
Thanks for the pictures and analysis/symptoms, very nicely done -- will remember this for if/when needed.
Not to get a thread on which is better, but since your like me and do alot of analysis -- what OPTI have you decided to install (oem, msd, etc), vented upgraded?, and from where?
