How can I tell what rear end I have?
Location: Inside every color vette there is a blue one trying to come out!
I have looked in the back at the rear axel...just in front of a 4 bolt plate with what looks like a grease fitting and just under the leaf spring I found a code: AN 1 13 65. This is stamped as best as I can tell on the bottom of something that the U joint and drive shaft go into. Is this the code that tells what the rear end is or is it something different? :confused:
Re: How can I tell what rear end I have? (Skruball73)
Thats the code AN. Just look up that code and if it hasnt been changed it will tell you. I dont have the books here.
At the very bottom of the differential, on the bottom flange where the cover joins the main body of the unit, is stamped code giving the axle ratio, plant and postitraction source. If you will give that information, I can access my neighbor's 73 Judging manual and tell you what ratio.
Gary
Gary
Re: How can I tell what rear end I have? (GaryS)
That rear end was originally installed in a 1965 Corvette with either the 327/350 or the 327/365hp engine. The AN Suffix is for the small block 3.55 ratio with Positraction. The 1 13 65 is the date of assembly. Now, the someone could have changed the ring and pinion inside, but it started out as a 3.55. This ratio would give you about 31-3200 rpm @ 70mph.
