Well this Vette brakes sale... i have to buy my Rear spring in the next two days... (advice)
330 lb fiberglass. Yae, nay? :D. I think i'm going for it.
Re: Well this Vette brakes sale... i have to buy my Rear spring in the next two days... (Jenny)
VB makes good springs. Have a 360 in mine. Get the right shocks though. These springs have a tendency to load good and rebound twice as fast. Makes for a very unusual ride. Call them up and ask what they reccomend.
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: Well this Vette brakes sale... i have to buy my Rear spring in the next two days... (Stingy74)
I got the 340 LB from Zips -- I REALLY like it, but it does need the right shocks.
Also, check the Tech Tips section for my write up on rear spring install. http://www.corvetteforum.cc/techtips...D=75&TopicID=3
Big time YEH, on that spring, I have one, rides much better, but I did put new shocks around also upon install, some fool told to go back to steel, so one day, I did...just for experiment.....and I was right, the VB plastic spring is a huge improvement.....
GENE
GENE
Re: Well this Vette brakes sale... i have to buy my Rear spring in the next two days... (Ed T)
......Some (maybe all) of those fiberglass mono-springs are adjustable so you can tune your ride from stiff to real smoothe. A friend of mine says his Vette rides like an Eldorado since he added his fiberglass mono-spring. I have used VetteBrakes products before and they are of good quality, but more designed for racing and therefore a stiff ride. You might want to shop around,talk to VetteBrakes tech support, or take into consideration what some of the other forum members are reccomending before you buy. Regards and have a great new year!
'74 Turbocharged 350 "Molested to Pefection," class of '71
I'm with Ed T on this one. The TRW rear spring is much smoother and more forgiving of improper shock selection. 315# is right for me.
With VB rear springs, you MUST have the correct shock. I suggest Bilstein Sport.
Paul Lisinsky will tell you that 80% of ride quality is dependent on rear spring performance.
Re: Well this Vette brakes sale... i have to buy my Rear spring in the next two days... (flynhi)
I'm not sure how it compares, but I put an '85 spring in my '75 and it works great. Better ride than the steel spring it had, and it performs great, too.
Matt
Matt
Talk to the Vette Brakes guys - get the kit with tubular A-Arms (top and bottom) with fibreglass spring. The kit (for back and rear) will run about $2100.
I've got it on both my SBC and BBC 1980's. You'll LOVE the way your Vette handles with this kit. With proper setup and wheels / tires, you'll give a C5 a run for the money on a slalom course.
I also own a Z06, and my smallblock 1980 with the kit handles almost as well as the Z06 - the difference is almost insignificant!
Have fun with your ride - it's great to see young women interested in owning and hot-roding Vettes.
[Modified by shawn_cake, 7:34 AM 12/31/2001]
Re: Well this Vette brakes sale... i have to buy my Rear spring in the next two days... (yellow 72)
......I'd be careful on that $2,000 VetteBrake set-up if I was you (mentioned previously, with all due respect). Strickly racing stuff. Stiff ride and noises from suspension I didn't know a car could make. I got tired of it and went back to mostly stock. Regards
'74 Turbocharged 350 "Molested to Perfection," class of '71
[Modified by Shutdown1, 12:26 AM 12/31/2001]
Re: Well this Vette brakes sale... i have to buy my Rear spring in the next two days... (Shutdown1)
The "stiff ride" is usually caused by people buying springs with too high of a rate. Tell the Vette Brakes guys the primary use of the car.. They will sell you the right sping rate. Also, the springs have adjustable pivot points - there are 5 settings for stiffness and jacking screws for simple ride height adjustment. No cutting coils! Ride smoothness is not of primary importance to me - I am interested in "sports car handling quality" - cornering and braking...
The noise factor can be fixed by:
1) Drilling the sway bar perches and polurethane bushings for zerk (grease fittings)
2) Lubricate the sway bar perches and the fibreglass sping perches (two on each sping) with Red-Line grease poly-urethane compatible grease.
I've had the Vette Brakes kits on my Vettes for 3 years - and yes - I did have the problems you talked about at the initial stage. Vette Brakes helped me fix those issues with the above mentioned fixes. After the fixes, I've had no complaints about the products!
:cheers: :cheers:
[Modified by shawn_cake, 7:51 AM 12/31/2001]
:cheers: :cheers:
Re: Well this Vette brakes sale... i have to buy my Rear spring in the next two days... (shawn_cake)
I have a 360# rear spring and it doesn't seem to be harsh. I drive on alot of "bad" roads. It's 8 years old and has 45,000 miles on it.
Scott
Scott
Not all of the FG springs are adjustable other than end bolt tweaking. If you want the adjustable kit, you have to ask for it. I have Vette Brakes springs on both of my Vettes (66 & 70) and neither is the adjustable style. I opted for the "stock" width spring so as not to have to put permanent inserts in my rear end threads. Several people have had the fiberglass springs crack/snap off. I had a steel spring snap off on my 66. As posted, you also need to add gas shocks for proper damping, otherwise you will be bouncing down the highway insted of rolling. Also agree with asking VB about spring rate- (in addition to us bubbas), they will set you up with the right spring rate and explain the rationale :)
PS- Carb kit?
Tom
PS- Carb kit?
Tom
High hp likes 420 inch pound steel.
Re: Well this Vette brakes sale... i have to buy my Rear spring in the next two days... (Tom454)
PS- Carb kit?
Tom
:cheers: :cheers:
:cheers: :cheers:
Thanks for your continuing insight into the VetteBrakes set-up. It just bothers me that I always seem to be re-engineering most of the aftermarket products I buy for my Vette, as you did with your suspension kit. I am glad you had such a positive relationship with the company, and that you are now happy with your performance Nice car! Regards
St. Jude Contributor
I just put the 330lb on mine a month ago. My wife noticed the improvement in her first ride since rear end rebuild. Major improvement! Just my $.02.
Good Luck!!
:chevy
[Modified by chevluvr, 5:08 PM 12/31/2001]
[Modified by chevluvr, 5:09 PM 12/31/2001]
Good Luck!!
:chevy
I just put the 300lb on mine a month ago. My wifes noticed the improvement in her first ride since rear end rebuild. Major improvemnent! Just my $.02.
Good Luck!!
:chevy
Good Luck!!
:chevy
