Squeeky suspension - usual suspect?
What's normally the culprit when the suspension creeks and squeeks over bumps? What a good replacement product?
I have a 97 A4 and to my knowledge no suspension work has been done on this car.
St. Jude Donor '08-'09
I use synthetic grease because I have it on hand and some rubbers are attacked by petroleum products.
the sway bars are the black bars that connects the left suspension to the right. on each end is a two swivel link. the bar is connected to the frame by two bushings. two fasteners secure each of the bushing brackets. the rubber bushings are split for easy removal. when both sides of the suspension are equal there is no torsonal twist to the bar and won't bite you when you loosen the brackets. no need to remove the end links to grease the bushing. the rear brackets are held in place by one of the lower control arm bolt with a nut securing it. when replacing the nut be sure to retorque to 43 ft lbs.
The endlink nuts are a bit difficult to torque given their location and their type... "pretty tight" works pretty well on these too.
The sway bar bushing brackets have an upper bolt and a lower nut. The top one is torqued to 49 ft/lbs and the bottom nut is torqued to 71 ft/lbs. It's really easy to do.
When you lube the bushing, make sure to get all the contact areas. One commonly missed area is the flat back of the bushing where it makes contact with the crossmember.
Here is a how-to for the sway bars to help you out.
http://www.ls1howto.com/index.php?article=16
Question, do these end links at the front cause a "clicking" when you accelerate from a dead stop? How would i know my end links need to be replaced? Any particular noises i should look for? This is at the front...
