Need Help With Suspension Upgrade
I have a 59 Corvete that I will be transplanting a 90' rear suspension into it. This I can hande with no problem (but as a first timer i welcome any pointers). But instead of buying a kit for the front, I was hoping to fabricate the mounting brakets myself, but having to keep the correct geometry, I am not sure how to proceed. Can any one offer instruction and a place to view what to do, or would it be best to just buy the front suspension kit (from Fatmanfab.com).
Thanks all and really enjoying becoming part of the forum.
Chris
Chris
Are you talking C4 IRS and IFS or something else? I'm doing a Dana 44 from a 96 Vette into a 56 Nomad, so if this is the direction your headed I may be able to help you with Info.
Good luck
Russ
Good luck
Russ
I built a '62 with C4 front and rear suspension. You can see the complete build at: www.carols62.com If you decide to go this route, I'd be glad to answer any questions you might have.
However, I would suggest that you might be better off buying a new frame that has provision for mounting the new suspension. If your old frame and suspension is in good condition you can probably sell it for almost as much as the cost of a new one. I am working on a '59 ( www.carols62.com/59 ) using one of Billy Dawson's frames, and I can tell you that it is much stiffer than the original frame I used on the '62.
If you can, you should go to Corvettes@Carlisle in August. There will be several exhibitors there that sell these frames, also numerous cars that have been converted.
Charles
Charles
Thanks for the input Charles. My frame is in great condition and a friend know's knows how to stiffen it up even more, but realy didn't think about a new frame due to budget. I also have the desire to do it myself. How much do you think you can get for a great 59' frame.
Also, to answer Russ's question. I am using the IRS from a 90' vette, and also wanted to use the IFS from the 90' vette also, but wouldn't use the cross member. So I would have to fab up the cross memeber and attaching points myself, but need to be on the money with the geometry. So is it worth it or just get the weld in kit from FatMAn Fab.
BTW Charles, the guys at FatMan had said that if my frame was in that good a condition, it's a keeper (their opinion anyway).
Charles
ok, so where do we stand??
ok, so keep the existing frame or get a new one? but ultimately, how would i go about fabricating the needed hardware and brackets for the front suspension while keeping the geometry.
also, for charles, why did you go with dawson and not progressive or even art morrison?
it also appears that i probably will not get more than 3K for my frame and i do not think it'll sell that fast either.
There is a guy on the Chevytalk forum that did something similar to a Nomad. Here is a link to his site: http://www.picturetrail.com/chevynut
2. His frame uses the full width C4 suspension (not sure about the others you mentioned)
3. Billy is a heck of a nice guy to deal with, very knowledgeable on all aspects of building one of these cars.
Note that with Billy's frame you will have to modify the rear differential "batwing" in order to fit in his frame, but that is something Billy can do for you if you don't like to weld aluminum.
Charles
...Also, to answer Russ's question. I am using the IRS from a 90' vette, and also wanted to use the IFS from the 90' vette also, but wouldn't use the cross member. So I would have to fab up the cross memeber and attaching points myself, but need to be on the money with the geometry. So is it worth it or just get the weld in kit from FatMAn Fab...
This is intresting. I have been wondering same at is it totally impossible to fabricate "bolt on" front crossmember wich would hold up the C4 A-arms and R&P .
I have found this crossmember kit wich seems to be quite easy to use / modify
http://www.seattlestreetrods.com/flatoutengineering.htm
Yes its far away from "bolt on" but much closer than starting from scratch
cli59
Charles has put you onto ChevyNut, He is doing C4 stuff to his 56 Nomad and I have used his web site to get much info for my car.
I'm using the C4 IRS and narrowed the half shalf to make the hub to hub width 60", this allows me to run a deeper dish wheel. for the front I will go with the Art Morrison Bikini clip, you can get this setup in several different widths. Check it out on their web site and see if it will work for you.
Good luck
Russ
Good luck
Russ
Thanks guys
Do i need to know anything to get onto ChevyNut? Thanks guys, this forum is new to me but you guys have all been Awesome. Hopefully one day maybe we will cross paths. I live in NYC.
name's Chris
name's Chris
I sent you an email.
Charles
The 56 nomad looks cool but i think there could be way more fabbing ahead compared to flat outs custom crossmember
But what ever floats your boat
