Distributor Heat Shield
HI,Was looking at the engine pictures from a couple of post's and saw that a lot of people don't have the distributor shield on. Mine is very tight on the wires and leaving marks on them does anyone have trouble with there's off.Was thinking of taking mine off.Thanks, Frank>STW<
Re: Distributor Heat Shield (NJ74STINGRAY)
Frank, no problem running without it. It was only installed on radio equipped Corvettes anyway and was designed to reduce possible electrical interference to the radio due to the cars fiberglass body; not a heat shield.
Mine's been off all year Frank. No problems at all. Call me crazy, but I like being able to see my distributor and wires :hat
Re: Distributor Heat Shield (Flareside)
Also, don't modern sparkplug wires prevent radio interference anyway? I ask the question, but I get interference on AM even with new wires and the distributor shielding! oh well..... MJ
Re: Distributor Heat Shield (Ed T)
HI, Thanks Guy's I just got home and have to look at it tomm, If I can not get the 8mm wires routed through it without them being pinched then I may just take it off.Thanks again ,Frank
