[Z06] If we're talking heat, let's talk radiators...
Another thread started yesterday engages the conversation of heat, and temps. seen by ZO6 owners. I already said my piece; if you live anywhere where it gets really hot-(almost everywhere in the summer), I say get an aftermarket high capacity... Better safe than sorry...
So, with this in mind, and while not trying to start a war, which is best and why? (opinions of course)
DeWitts or Ron Davis or other? Lay it on me.
Ron Davis for me!
Former Vendor
I found that 99% of people will recommend what they bought because it justifies their choice and decision. We all do it. I just bought a new LG HDTV and I love it, but that's my only experience with HD. I really don't know if the others are better quality, but I'll go on and on about the great deal (i think) I got. My point is, only someone that has used several brands can really give an accurate accessment of the products.
I also understand that about 50% of what I say on the forum is presumed propaganda, and I'm ok with that. So here is my opinion...
I think RD makes a fine product, probably one of the best made radiators on the market. Contrary to popular belief, we use the exact same cores, with the same fin count and tube width. Which means they both cool exactly the same, neither is a better cooler. Often I hear someone say "use the RD for racing and DeWitts for drivers" and I have no idea where that comes from.
DeWitts offers these differences:
1. We specialize is Corvette radiators only, nothing else.
2. All major Corvette dealers selected DeWitts for fit and function
3. Prices are lower
4. Delivery is better
5. Warranty is 3 years
6. We use press formed end tanks without cuts and welded seams
7. Direct Fit radiators require no mods to install
8. Our oil coolers are bigger and centered to minimize retrictions
9. DeWitts is a Corvette forum sponsor (paying the light bill here)
10 We make our own cores in our new nocolok furnace
Hope that helps
3. Prices are lower
Hope that helps
Premium Supporting Vendor
Either DeWitts or Ron Davis would be great. If you want to something that will REALLY enhance either of them, get a louvered hood.
Cooling Difference
Anybody know - Tom probably would - how much more cooling capacity a Dewitt/RD (if the same tubes) has than the factory. Or maybe just general capacity differences not sure how big the factory C-6 Z 06 radiator is in fin size and rows (1-1 inch tube versus DeWitts 2 - 1 inch tubes?). Is there some kind of a BTU rating??? I thought I also saw somebody got about 20 degrees cooler than stock with a DeWitt's.
Former Vendor
I have a Dewitts in my LSX TT C6Z06 and think it looks and works awesome. I even have the custom 2 fan shroud setup.
I give a big thumbs up to Dewitts! (maybe because I own one)
Former Vendor
The Z51 (internal type) are nice too, but we are limited to how big they can be because they have to fit inside the end tank. Our coolers are more than double what GM used (7 plate vs 3 plate) and it really is plenty of cooler for 99% of the applications. The drawback here is the heat removed from the oil goes into the coolant. The other problem is that these coolers were not designed to handle 100% of the oil pump flow and they should use a 7 psi bypass (like the factory GM unit has). That a whole new discussion.
There is the World Challenge hood
LG has one
Caravaggio has a vented hood
Anything with a frame underneath is solid. If you're doing a lift off hood you may need some reinforcement.
Former Vendor
Randy
One thing that Tom DeWitt notes - - If Ron Davis makes a unit for the ZO6, why is there trimming needed for the shroud? As Tom states, his requires no trimming. I want plug & play. Anyone want to venture a guess? Are there material advantages to fan upgrades? Anyone with personal experience with this?
Former Vendor
Member since Jan 2000
Cooler Z06s
We changed our fin density for late model cars because we recognized most of these upgrades were for high speed racers. We can do that because we make our own fin, we assemble our own cores, and we braze them in house in our own state of the art furnace.
So far i have gotten 5 units from you sent to to the UAE. two have been installed and the owners of the two cars are very happy with the reduction of temp in our 115+ temps. The other 3 will be in hand on saturday and installed by monday. will keep you posted on those as well.
On a different note, when i hook up the tranny cooler lines to your unit, how much oil should i add?
finally, thanks for the great service and special thanks to Christyn for arranging all for us.
