Floor pans getting soaked
Cruising
Is there a common leak point at the fire wall windshield area? My floor pans are getting pretty wet and I think that it must be coming from the fire wall area. If this is common, how bad is the fix?
Re: Floor pans getting soaked (Hokievette)
I did several thing to mine solve this problem:
1. Cleaned out the plenums (? not sure if that's what they're referred to or not, but the cavities) at either end of the cowl (below/in-front-of the windshield) area.
2. Caulked all of the seams in the cowl area.
3. Covered the cowl area with undercoating (probably not the proper material, but I thought it looked good).
4. Caulked the rubber strips at each fender where it meets the windshield (probably should have replaced the strips; I think this may have had the greatest impact on stopping the leak).
5. I also removed the windshield pillar trim and checked the condition of the windshield pillars to see if they were rusted (just surface rust, I was happy to see).
I'm sure there are some other suggestions people will offer, but these may get you started.
My only leaks now are related to worn weatherstripping.
Good Luck.
Oh, yes this is a very common problem. You may want to search the forum & the Web for articles & solutions.
[Modified by jerryp58, 10:26 PM 12/25/2001]
Good Luck.
Platinum Supporting Dealership
Re: Floor pans getting soaked (jerryp58)
I just spent weeks fighting this. The best way to go about it is use a squeeze bottle and try to isolate it. The thing that happens most often seems to be the seams between the firewall and the front end. The worst part is that you really can't get at it without bending a brush and putting it in that little area you can see only when the door is open.
What happens is that the car flexes and the seam sealer cracks or breaks over the years.
[Modified by Rhys, 11:10 PM 12/25/2001]
I had the same issue and it turned out to be coming in through the doors. There is supposed to be a piece of plastic that seals under the the door panel to keep water that comes around the window from getting inside. The water should channel through the door to the rear where there is a hole for it to escape. Mine was missing the plastic. I installed a heavy gauge piece of visqueen around the door panel and calked around the perimeter, it stopped the water from hitting the bottom of the door channel then soaking through the carpet to the floorpan.
