Factory GPS ant location?
Well, the title probably asks the question just fine....but where is the factory nav GPS antenna located? I am just curious. Is it mounted under the molding of the dash? I had thought it was under the center channel grill, but then say a picture that looked like it was mounted just above the AC vents on the console.
It is right above the drivers side center vent.With the center stack removed you can get to the push pin locks and get small screw driver to pry up the locks and remove the antenna and the plate it sits on.
I just did it this week.
Mike
Mike
