C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] 07Z Tranny versus 08Z Tranny
Old 07-02-2008, 09:44 AM
Tom Beames
Tom Beames's Avatar
Default 07Z Tranny versus 08Z Tranny
Help! I had an 07Z and had difficulty with the 2-3 shift and, to a lesser degree, the 3-4 shift. They just didn't seem to line up or something. It almost seemed like there was not enough "room" for the gears to fit.In reading the CF I have read of only a few writing about this issue. What I learned from someone here is that the tranny fluid must be "warm" and the shift will be smooth. This had worked-I used the oil and water gauges to determine when we had reached ("we" meaning meaning me and the car) normal temp. I am told this is a good indicator. However, until we reached "normal" the issue exists.
I now read that GM has created a different tranny for the 08Z.
1. Will the 08Z tranny fit into my 07Z? (Assume I have the money, which I don't!)
2. What change did GM make?
3. Was the change in any way related to my particular issue?
I have since traded my 07Z some 7 months ago but she is STILL on the dealer lot. He wants $59,500. Car has 10k miles. !!!!!!! I have a hankerin' to buy her back but I first have to get this issue of the shift points straightened out-at least in my head. I currently have an 04Z which is nice but it ain't no 07Z. 505HP is a "ton" and runs like a bat out of heck!! I miss the fact that I don't have to get out of second gear much before 85!!!!
Thank you all,
Tom Beames
GR8KAR
Old 07-02-2008, 10:52 AM
patton
patton's Avatar
St. Jude Donor '09
hard to believe
Old 07-02-2008, 11:09 AM
TAILWAG
TAILWAG's Avatar
Yes, the 08 tranny is better/different. Some people are still complaining about other issues with the 08. If you have an 07, and if you buy it back...it is still warranty covered...they should fix the issue...but, seems GM is trying to get out of covering anymore, so I don't know.
Thank you all,
Tom Beames
GR8KAR
Old 07-02-2008, 11:50 AM
Paul Scarpelli
Paul Scarpelli's Avatar
The Z06 transmission discussions are actually funny. Most fanboys of the older trans, the T56, speak glowingly of it because it's lighter, they like how it shifts better, etc. But the new TR6060 flat out works better. I've owned three T56s in a row, and the 2-3 shift is always an adventure ending with either a 2-5 shift, or the linkage jamming. I've found that a new shifter from Hurst, B&M, whatever, will greatly improve the T56 to at least the performance of the new TR6060. You should probably try that first...it's a lot cheaper. I don't know what the current "uber" shifter is.
An aftermarket shifter will shorten the throws and help with the 2-3 shift. BTW, I have blown a shift already; and I'm good; with my TR6060. I'll probably do an aftermarket shifter with it, too.
Good luck.
Old 07-02-2008, 12:33 PM
dgdoc
Support Corvetteforum!
dgdoc's Avatar
Good luck.
I might be alone, but don't believe there is an inherent problem with the 2-3 shift on a T-56 that isn't related to technique. I had similar problems as you described initially, but followed the advice from Ranger, Dr. Ron, and others to only use an open palm when making the 2-3 shift thereby allowing the springs in the linkage to do their thing without me trying to "steer" the shifter either intentionally, or unintentionally. After this, no more issues.
Not saying you didn't have issues with your T-56 tranny's, or that the T-56 is superior to the TR-6060 (doubt it is), just relating my own experience.
Anyway, would be interested to hear from other folks who maybe had the same issue and were able to adjust their technique to avoid the problem.
Old 07-02-2008, 01:35 PM
tigertank
tigertank's Avatar
hmmm what is the weight diif? ive heard its 08 is heavier, is it worth the extra weight? is it THAT much better?
Old 07-02-2008, 01:39 PM
TAILWAG
TAILWAG's Avatar
I would be willing to wait it is not even 1 lb...
Old 07-02-2008, 09:43 PM
ZL-1
ZL-1's Avatar
Somebody wrote that the T6060 is 30 lbs heavier but that sounds crazy. It's probably much less. Does anybody actually know the weight difference between the T56 and the T6060?
Old 07-03-2008, 12:18 PM
GMuffley
GMuffley's Avatar
I have no issues with the T-56 in my 07.
Old 07-03-2008, 12:43 PM
Cape Cod Bob
Account disabled by user request 2 March 2009
Cape Cod Bob's Avatar
Had an '06 and missed a couple of 2-3 shifts. Now have an '08 and it shifts better than the '06. No missed shifts either. So, my vote is for the '08 shifter.
Bob
Old 07-03-2008, 01:09 PM
augydog
augydog's Avatar
St. Jude Donor '08-'09
Neither do I, cold, hot, humid, or dry.
augydog
Old 07-03-2008, 02:13 PM
07Z06SD
3rd Gear
07Z06SD's Avatar
I would like to know the differences too. Currently I don't have any issues with my 07 transmission. Car has 12k miles. I do get clutch slip sometimes with nitrous.
Old 07-03-2008, 02:19 PM
mrwrenchphd
mrwrenchphd's Avatar
augydog
Same here & I've tracked it hard several times on our local road course. Works just fine for me. Me thinks most problems are operator error.
Old 07-03-2008, 03:41 PM
xcutter
CF Senior Member
xcutter's Avatar
All us Vette owners probably vary in weight by up to 150 lbs. Unless your the size of a Jockey, how much does it really matter. I weigh 230 lbs. I can lose 10 lbs to make up for the extra tranny weight.
Old 07-03-2008, 03:51 PM
AtlBlkZ06
AtlBlkZ06's Avatar
According to many sources online, both the T56 and TR6060 weight the same 121lb.
Some list the T56 as "115-129lb"
http://www.steeda.com/products/tremec_t56_gm.php
The TR6060 is 121lb according to:
http://www.corvetteactioncenter.com/...008tr6060.html
Old 07-03-2008, 03:59 PM
TAILWAG
TAILWAG's Avatar
The weight difference is probably with the 60 having been topped with fluid and the 56 dry as a bone...
Old 07-03-2008, 04:00 PM
TAILWAG
TAILWAG's Avatar
Whoever wrote that weight the T60 with fluid and the T56 without any as they weigh almost identical...some much more reliable sources have the weight exactly the same...
Old 07-03-2008, 04:04 PM
Turbooo2u
Turbooo2u's Avatar
RANGER and his 06' didn't get into the 10's by blowing the 2-3 upshift.
To 07Z Tranny versus 08Z Tranny
Quick Reply: [Z06] 07Z Tranny versus 08Z Tranny
