Any Real use for the By-Pass Hose, I went through Hell Finding-one
After replacing my leaky by-pass hose, I questioned is it realy needed.
Re: Any Real use for the By-Pass Hose, I went through Hell Finding-one (73-454)
I ran my engine with it and with out ...and didn't see a noticeable differance :yesnod: Found mine at "Advance" auto parts stock item :cool:
Re: Any Real use for the By-Pass Hose, I went through Hell Finding-one (mrvette)
Small 90 degree hose from the top of the water pump to the intake manifold.
Re: Any Real use for the By-Pass Hose, I went through Hell Finding-one (Tom454)
I got one for my 68 bigblock at Napa. It looked exactly like the one I replaced. MJ
C6 the C5 of tomorrow
It's a big block thing. small blocks have a third hole on the drivers side of the waterpump hole.
And YES the Bypass hose is needed unless you drill your thermostat. See without a bypass when the thermostat is closed there is no water flow through the engine. This means the engine must heat the thermostat by convection untill it opens and water starts to flow....
Pardon my brain fart here, but 'bypass hose???' where is it??? runs from where to where????
GENE
GENE
