HELP HELP HELP HELP DIFFERENTIAL MOUNTING!!!!!!!!!!!!!!!!
I can't remember how to mount the differential with the cushions...
I have 2 cushions; 1 big and 1 small. Then you have the large washer and the small washer and a lock washer...
I am guess large cushion on the bottem??? I can't remember what goes where.
I have an 80, auto. thanks!!!!!
Can you list it from the bottem up! ??
I think it goes:
lock washer
large washer
differential
large cushion
frame
small cushion
small washer
and the bolt
[Modified by Bluewasp, 11:46 AM 12/25/2001]
I think it goes:
lock washer
large washer
differential
large cushion
frame
small cushion
small washer
and the bolt
Re: HELP HELP HELP HELP DIFFERENTIAL MOUNTING!!!!!!!!!!!!!!!! (Bluewasp)
From bottom up,instructions from vette breaks,1nut,2lock washer,3small steel washer,4large steel washer,5these go on below the differential 6large poly bushing goes between the diff and thecrossmember,7,on top of crossmembersmall poly bushing(step goes down)8,1 piece metal sleeve with washer attached,9, small steel flat washer,10, bolt. dont forget the anti seize on the threds,torque to 40 ft. lbs. hope this helps.
Re: HELP HELP HELP HELP DIFFERENTIAL MOUNTING!!!!!!!!!!!!!!!! (1yy07)
yup.. that is what I needed to know.. thanks!!!!! :D :D :D
