Pic's of new Paint Job!
Well, finally I'm close to complete with the paint job. I'm still going to wet sand the rear bumper cover again so I haven't installed the Corvette letters. All in all I'm happy, but what alot of work. Start to finish it took 4 months working most week-ends. But it sure feels good to drive around.
[Modified by Paul 75 L82, 8:14 PM 12/23/2001]
Re: Pic's of new Paint Job! (Paul 75 L82)
I would like to thank Lars for his help. I never would have taken on a project like this without his article on Corvette painting. It seamed like I emailed him many times to ask questions and he always replied. Thanks Lars.
an already stunning car, turns into a show car... that paint looks great... you think it would go well with a blue interior?
ZD :cheers:
ZD :cheers:
I know how you feel when you finished your car, all your free time working on your car. But after all the work is done sit back with a cold one and pat yourself on the back on a job well done. I'm glad to see there are people out there not affraid to tackle a paint jb. http://'http://temp.corvetteforum.ne...et1//hardwork3
Re: Pic's of new Paint Job! (Nomad78SA)
Good job Paul. Lars helped me do the same. He saved me thousands, and I learned volumes. Another forum paint job for the record. :)
Great job. :) Looks really nice. I painted mine in two weeks, that was ***** to the wall, sanding/fiberglass repair everyday after work, and lots of weekend work. :)
Re: Pic's of new Paint Job! (wadew10)
PPG Deltron Paint (#74 Dark Red) 3 Qt DBUSC 2658 $194.70
PPG Reative Reducer 1 Gal DRR 1170 $35.45
PPG Concept Clear Coat 1 Gal DCU 2021 $138.40
PPG Clear Coat Hardener DCX 61 $64.15
[Modified by Paul 75 L82, 9:15 AM 12/24/2001]
For what it's worth. Here's the complete list.
Paint Job
Fiberglass Stripper (4 gallons) KLEGAF354 $101.64
Wax & Grease Remover 3919S-1 $15.67
16" Sanding File HUT-5502 $24.33
11" Sanding File HUT-5504 $22.95
80 Grit Roll Sanding Paper 3M-2599 $33.13
150 Grit Roll Sanding Paper 3M-2596 $33.13
220 Grit Roll Sanding Paper 3M-2594 $33.13
80 Grit Sandpaper Sheets 3M-2018 $26.02
150 Grit Sandpaper Sheets 3M-2015 $11.87
220 Grit Sandpaper Sheets 3M-2007 $13.78
Sanding Block $7.37
Vette Panel Adhesive FIB-870 $22.54
Door Springs A4301 $7.99
Door Spring Tool A4300 $11.99
Gasket Door Locks(3@$0.50ec) G658 $1.50
Outside Mirrors, car set (ZIP) ZIP-MR-355 $99.95
Handle Gasket, pair CR-G627 $8.00
T-Top Weatherstrip B462L/R $89.00
DP50LF (2 quarts) $69.11
DP402LF Catalyst 1 qt. $33.07
DT885 Reducer 1 gal $33.28
K36 Prima Surfacer 1 gal $115.33
K201 Hardener 1 qt. $49.66
Respirator 3M-7193 $16.58
Air Filter HA507 $6.84
Astro Paint Gun AST-GF20 $95.35
600 Sandpaper 3M-2000 $15.05
220 Sandpaper 3M-2007 $10.49
Masking Tape $10.13
Grey Scothbrite $4.83
Misc Plastic Cups $9.28
Tack Rags $5.88
Lacquer Thinner 2 gal $12.67
White cotton Rags $10.60
Emblem, Front "Sunburst" A2012 $77.99
Emblem, Rear Gas Door A2044 $83.99
Emblem, Stingray A2031 $20.99
Emblem, L 82 A2013 $19.50
Letter Unit, Corvette A2043 $42.99
Nuts, Front Emblem, 2 required A5575 $4.99
Lamp, License assembly A2497 $10.50
Retainer, Door Locks(3@$1.25ec) 26773 $3.75
Door Handle, outer 26870 $59.99
Door Handle, outer 26871 $59.99
Door Handle Rod Clip (2) $1.25 ec 20391 $2.50
Lamp, Side Marker Rear A2600 $15.50
Lamp, Side Marker Front A2599 $15.50
5 Gal of Wash Thinner SCI ST6 $18.00
Painter - Jerry Arnold $800.00
Clip- Door Handle to Mechanism KDR-322 $3.00
T-Top Lock Plate (2) A2691L/R $21.58
T-Top Lock Plate Pin (2) A2690 $11.70
Antenna Gasket to Body A2192B $2.03
Paint Job
Sanding Block $7.37
Masking Tape $10.13
Tack Rags $5.88
Very nice looks, Paul!
It makes a perfect pic with the Palms in the background!
I like it very much, I own a 77 too and it always remembers me of my holidays in Florida which have been too long ago...... :cry
