How to OHM check Injectors (instructional video)
Old 06-18-2008, 10:39 AM
FICINJECTORS
Supporting Vendor
FICINJECTORS's Avatar
Default How to OHM check Injectors (instructional video)
I have been getting a lot of e mails on how to check injector coils. You should do this 1st cold and then hot
Old 06-18-2008, 01:46 PM
johnnyevans
johnnyevans's Avatar
Way to go Jon! That should help a lot of folks.
Don't forget to check them hot and cold too!
BTW, injectors are working fine on the convertible! I am looking forward to the # 42s on the turbos, when I get them in finally!
Thanks
Johnny
Old 06-18-2008, 01:53 PM
rick lambert
rick lambert's Avatar
Here's a question Jon,
When I first learned how to ohm my injectors (87) stock, I was told they should ohm around 16 +/- .5, well, they did, so I past that information on to others. Later one of the forum members asked me where I came up with the 16, I couldn't remember, so I looked in my 87 FSM. It says they should ohm at least 10. So, what yrs. should ohm where? As far as I'm concerned now, as long as their all within +/- .5, it seems to me that's the most important criteria. Is that right?
Old 06-18-2008, 03:14 PM
FICINJECTORS
Supporting Vendor
rick heres the rule of thumb I use. The 85-86-87-88 with some late 88's having lucas were early design Bosch pintle injectors. The coils in those i have seen from 10-14 . even most of the new Bosch injectors are in th 14 range. The multec should be around 16 but seem to work fine at 14+. But the whole set should be within +-.50. The new ls1 bosch injectors are 12.8 and most of your aftermarkets are in the 12-14 range. All I can tell you is that when a Multec has a reading of below 10 they start thinking on their own.
Old 06-18-2008, 04:48 PM
pmihaltian
Slingshot
Support Corvetteforum!
pmihaltian's Avatar
Great video, Jon. You are the best.
Now how about showing us dummies how to get the wire hold-down clips off without bending or breaking them.
Old 07-21-2008, 10:12 PM
DWC4
DWC4's Avatar
Default awesome, thanks John
Terrific, thanks, answered my questions with your various posts about LT1 injectors. I'll test at 2K range for around .017 value on all, any much below or above (beyond .0005 I guess it would be) is suspect but .012 or below definitely a problem unit from what I gather.
Old 07-21-2008, 10:42 PM
schrade
schrade's Avatar
Sticky.
How do you get the mods around here?
Old 07-21-2008, 11:10 PM
schrade
schrade's Avatar
You guys PM the mods to sticky this...
Everyone makes their own injector thread / FPR thread, and they all get buried. Sticky this, and your threads won't get buried so fast with new ones...
My
Old 07-21-2008, 11:16 PM
cwyates4
cwyates4's Avatar
Originally Posted by schrade
Sticky.
You've got to be naughty first.
I think we should just let Jon make one big, fuel related sticky.
Old 07-21-2008, 11:21 PM
schrade
schrade's Avatar
That's a lot of work for 'free'.
Somethin' needs to be done tho', there's 7 FPR and injector threads in the first 30 threads right now.
Old 07-21-2008, 11:27 PM
FICINJECTORS
Supporting Vendor
why can't there be a TPI forum like third gen
Old 07-21-2008, 11:34 PM
cwyates4
cwyates4's Avatar
That is pretty nuts; I usually don't shout about the search function, but wow! Its there for a reason.
If Jon made a big sticky, he'd probably save himself some work. He's constantly posting the same info to people everyday.
Old 07-21-2008, 11:36 PM
schrade
schrade's Avatar
Push.
Old 07-22-2008, 06:37 PM
schrade
schrade's Avatar
ttt.......
Old 07-23-2008, 02:33 AM
Knooger
Knooger's Avatar
CI 6-7-8 Veteran
St. Jude Donor '06, '07, '11, '17
Old 07-23-2008, 02:43 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
FIC is a class act. Im ashamed I dont know how to use my multimeter. Know the voltage/ohm amounts to check, just used to flip the switch around til I hit on what I thought was the right one
Dont know an ohm from a Volt
Learned something tonight.
Old 07-23-2008, 06:17 AM
Weav's Vet
Weav's Vet's Avatar
That would be me to! Thanks Jon! Another great video!
To How to OHM check Injectors (instructional video)
Old 07-23-2008, 08:16 AM
floridamale
floridamale's Avatar
Great post Jon I'm sure this will help lots of readers here.
Old 07-23-2008, 09:37 PM
tpi 421 vette
tpi 421 vette's Avatar
I have nothing but good to say about Jon. He bends over backwards to help people And my injectors are working perfect after Jon cleaned and flowed them.
Old 07-23-2008, 09:41 PM
cdnguyred88
cdnguyred88's Avatar
This will help a lot of us, plus myself. Thank you very much.
Quick Reply: How to OHM check Injectors (instructional video)
