Do the make an oil filter with a drain plug?
I am tired of getting the full oil filter spilling down my arm every time I change the oil in my '72. Do they make an oil filter that has a drain plug? That straight down oil filter on my 350 is killing (soaking and staining) me. Any ideas.
Kman in SC
:confused: :mad :nopity
Kman in SC
Re: Do the make an oil filter with a drain plug? (Huzker)
Just punch a small hole in the bottom of the filter before you unscrew it and let the oil drain out - no big deal....
Re: Do the make an oil filter with a drain plug? (KenSny)
Sweet... Sometimes the most obvious eludes us. Why didn't I think of that?
Kman Huzker
SC :eek: :crazy:
Kman Huzker
SC :eek: :crazy:
If there is one they should ban it cause you someone would buy it and never change the filter again.
Re: Do the make an oil filter with a drain plug? (MNJack)
ramair (MNJack)
Where did you learn to spell and complete sentences? It sounds like the school system in Indiana has a lot of work to do. If you cannot give an intelligent response (which it looks like you struggle with) maybe you should just not respond. :boxing :D
Kman Huzker
SC
[Modified by Huzker, 1:04 PM 12/21/2001]
Kman Huzker
SC
Thank you for your response to my response,it really means alot.
Im sure I'll give it every consideration when I respond again.
Thank you ole kind sir!
I hope someone steals the "W" off your keyboard Mr. President.
QUOTE: If you cannot give and intellegent response (which it looks like you struggle with) maybe you should just not respond.
Correct Spelling is Intelligent. Improper use of the word and
:troll
:troll
Re: Do the make an oil filter with a drain plug? (ScubaJKD)
Crack the filter loose and wait 1/2 - 3/4 of a MO. This will let the extra oil out and then you can continue.
Does anyone fill their filter up before installing it?
A minor thing but the engine gets no oil till the filter is filled first.
Re: Do the make an oil filter with a drain plug? (Techno)
I always fill mine about 3/4 of the way in my truck but in my wifes car I can only fill it aoubt 1/4 of the way because it goes in sideways. Not sure where I read it but I read once its good for the engine and I've been doing it for the last 12 years.
Cruise-In IV Veteran
St. Jude Donor '03-'10
and how deep do you have to punch?
Re: Do the make an oil filter with a drain plug? (Chris Fowler '80)
I use an awl and it's maybe 1/8" in dia. but you can use a screwdriver blade if you want. Whatever, the cannister is not very thick.
Here's an old trick to get off a filter that someone has really tightened. Jam a long screwdriver blade in one side and out the other, then use the screwdriver as a breaker bar to twist off the filter.
St. Jude Donor '11, '16-'17
I do this everytime I change the oil in my truck. The filter holds more than 2 quarts of oil, and with all that weight, it's easy to drop and make a mess
