Re-installation of the power brake booster question.
Re: Re-installation of the power brake booster question. (JRChurch)
that retainer clip is eeeeeeviilll
666
:cuss :cuss :cuss :cuss
make sure u bend it good enough so it dont pop off again whil eyour driving and the pin pops out and you have no brakes..
that would be a bad day.
666
4th Gear
Rick,
You can get one from your Cehvy parts guy. The part number is 9791640 and the cost is $3.90.
Bill
Bill
Rick,
the gasket is for thermal insulation only.
Either silicone or some other elastic sealant will easily do the trick.
Popping the bolt in depends on the rod of the booster.
You can pull the rod out or press the pedal down - whatever works better!
Its just a trying thing, ok?
C U :flag
C U :flag
