'05 thru '07 C6 Key FOB Remotes for sale...pic
I have three fobs for sale...all have been tested with my '07 Vert to make sure they work perfectly. $60 each shipped in USA by Priority mail envelope. Buy more than one and I'll knock off the shipping on the second one. One is #1 and two are #2 Fobs....but remember that the number on the fob is meaningless...the order is determined by which is programmed to the car first. Also will work fine on '08, but obviously doesn't have the metal key inside. Great for a spare, and less than half the dealer price. Includes instructions and I will be happy to help if needed over the phone. I have programmed many and it is very easy! ALL THREE SOLD
Question?
The Passenger Door On My 06 Vert,doesnt Unlock All The Time,and I Have To Hit The Door Button Or Push The Unlock Button On The Fob, Do U Think The Battery Is Low In The Fob Or Some Other Problem?? Also,what Do U Think Of The Item U Can Buy And Plug Into Ur Service Port And Make Ur Key Fob Operate Ur Windows And And I Think Control Ur Radio??
Its called the Window Valet and it only does the windows, but I have no experience with it. For me, I would never care about opening windows from 50 feet away as I'm going to be at the car in another 15 seconds anyway.
Also the bubble over your car is cool!
Just saw this posting. I bought a FOB from cclive awhile back and he shipped super fast and the FOB was perfect.
As to the window valet. I have one and you can roll your windows up or down with the FOB. I guess it helps with the heat, but I'm kind of on the same page as cclive about being right there anyway. However, I find it most useful (and the reason I bought one) when I'm trying to get in the car in a tight space and I can't open the door as much as I'd like (ie - in our garage). Having the window down lets you lean as you get in which makes it easier because the window curves in a bit...so I was having to do gymanstics to wiggle into the car.
The other functions it has are:
1) It can show you the highest speed and RPM that the car was driven at before it was reset last. I guess that's good if you have a valet park your car or something and want to check to see if they hot rodded it...
2) It has a function where if someone pushes the door pad button to open the door and there is no remote present it will honk the horn (2 or 3 times I think).
Both of those functions are set to "off" when you get the window valet and I've never turned them on...so obviously I don't find them useful...but I'm sure some love them.
Anyway, just popped in to say that cclive was a great seller
Rob
Rob
