OEM 2002 C5 Z51 Suspension
Just had the OEM Suspension pulled from my car to upgrade to coil-overs. All of these parts have a little over 54K miles on them. pics coming soon. Prices listed do not include shipping.
Front & Rear Springs: $150 - SOLD
Front/Rear Sway-bars w/ metal end-links: $150 - SOLD
4 Shocks: $50
I also have some small parts like tie-rod ends and camber eccentrics, that I'll add to this post when I get a good inventory of it all, but for now, pretty much everything you can see being removed here is up for grabs.
Springs/Sway-bars
Shocks
4 Shocks: $50
Springs/Sway-bars
Shocks
I am interested in the z51 items, but have ????'s
Hello, I have a 2000 c5 and was wondering what the z51 upgrade will do ?
.(such as smoother ride and more responsive handling.)And are they easy to install?
the idea is to make the car more responsive than OEM, stiffer spring rates, stiffer shocks, & bigger sway-bars.
Spring Swap
http://ls1howto.com/index.php?article=20
sway-bar swap
http://ls1howto.com/index.php?article=16
Shocks aren't anything big for a good mechanic and you can probably find a how-to pretty easy.
Spring Swap
sway-bar swap
Shocking
4 Shocks: $50
I also have some small parts like tie-rod ends and camber eccentrics, that I'll add to this post when I get a good inventory of it all.
4 Shocks: $50
Also, do you have the front cross member spring/Leaf? I can't remember the name of it right now, but its the leaf that attaches to the cross member and the suspension.
I'll figure it out and get back to you, but the shocks for now, please.
Toby
yes, 4 shocks for $50 total, just based on their age and use over the last 6 years.
the leaf spring is what you're looking for. selling front & rear together for $150. I'll consider splitting it up later, but would rather keep them as a set for now.
PM replied
as far as I know, any of the optional suspension parts will bolt right up to any year C5
also if you want to see the parts before they came out of the car go here until i get a chance to clean everything up and take some good pictures.
http://forums.corvetteforum.com/show....php?t=2025828
I'll def take the swaybars and endlinks.
Possibly also the springs.
Can you get me some shipped prices to 77568 zip code.
For Sways/endlinks only and for sways+springs.
Are the springs different than the base 97 springs? I assume stiffer.
It ended up working (for now), but the adjuster was completely siezed on one side of the front spring. Strange....
http://forums.corvetteforum.com/show....php?t=2054176
