Generator light in my '79
St. Jude Donor '11, '16-'17
It stays on, even though the system is charging fine. Has anyone seen this problem before? Where should I start looking? Thanks!
Re: Generator light in my '79 (The_Dude)
Disco the connector from the alternator. If the light goes out it might be a bad diode in the alternator. Have it bench checked. If it stays on, then the wiring has found a ground is making the light iluminate. lou
Generator? Sure it isn't a 59 Vette? All joking aside, that is usually the sign of an alternator going bad.
Re: Generator light in my '79 (76Pitter)
Re: Generator light in my '79 (Neo Fender)
A easy check is to place a screw driver to the back of the alternater near the bearing. engine off it should be slightly magnetic. Engine on highly magnetic.
I'm wondering if it could be an over voltage instead of no volts. Does a gen light come on when the voltage reg dies?
BTW generating stations that produce your home electricity use generators, even though they are alternators. Go figure.
