Where can I go to look up original GM Part mumbers??
Re: Where can I go to look up original GM Part mumbers?? (Barry's70LT1)
I need to check out 041 heads if ya could..I wanted to find out compression and what they came on originally
Re: Where can I go to look up original GM Part mumbers?? (Alwyn678)
heres some info i found...
"041" – 3947041, also 3947041X. A good performance head. They were found on 1969-1970 302 and 350 engines. They had either 1.94/1.50" or 2.02/1.60" valves, 64CC combustion chambers, DO have accessory holes, I don't have port volume data for the regular 041, the 041X intake port should be 165CC's, the 041X exhaust port should be 65CC's. These heads have a single somewhat triangular shaped casting mark (slope on the upper left).
Re: Where can I go to look up original GM Part mumbers?? (daily_driver)
just in case anyone else wants this link....
compression ratio calculator..
http://www.turbofast.com.au/TFcomp.html
