Brake bleeding tip
Re: Brake bleeding tip (JRChurch)
if you have the money, then take it to someone with a power bleeder..
those things are badarse!!!
i wish i had one.
i wish i had one.
I got 64 fl. oz. because it was only like $3.99 for two 32 oz bottles...
I did it like you, bled until I got new fluid, it took forever, and I only have a little bit left in one bottle, the other is empty. So I think 64 is a good choice, it's not to expensive anyway.
Daniel
Daniel
With two folks, probably no more than an hour or so. I'd recommend buying three or four of the small bottles. If you have an opened can it will absorb moisture from the air. Check level often, if you run it out, you start all over. Good luck! :seeya
